.jed viewer for XP
.jed viewer for XP
I would like to know if there is any program to view a file with a .jed extension.
This type of files is used in programs for PAL's.
Best regards, Carlos Cardoso
RE: .jed viewer for XP
It is just an ASCII text file : NOTEBOOK can read it.
If you have difficulty, copy it into a XXXX.txt file.
It is not too difficult to xlate it into equation if
you know the PAL type.
<nbucska@pcperipherals.com>
modified for onther type. What is the type of the PLD
you are interested in ?
If it worked i would be gratefull!
be simpler if you could tell the full type# of the PAL- I
wrote the program for the 20L8 so it may have to be
modified
different PAL types e.g. 16L8,16H8,16R8,16R6,16R4 and some
other strange types.
My program was written to xlate the 20L8 but I am sure I can convert it for whatever you use.
