Ideal expansion in heat engine?
I am considering using an a/c rotary vane compressor as an expander in a solar generating project. The working fluid is R134a refrigerant. From volume measurements I've determined it takes a 12cc space to a 36cc space before dumping, or 1:3. From what I've heard it should be more like 1:9. I've considered using a smaller and larger unit in a compound configuration or installing a cutoff device at the inlet. My questions are:
1) What is the ideal expansion ratio for efficiency regardless of resulting power/speed output?
2) What is the correct sizing steps for double and triple compound expansion?
3) Does throttling behave in any way like the results from a admission percentage cutoff device?
RE: Ideal expansion in heat engine?
Thus it would be nice to have expansion 1:9 but you have to provide sufficient compression first.
