Thread Detection
Thread Detection
Does anyone know of a sensor or system that can verify if a hole is threaded? This is for poke-yoke purposes and the system or sensor needs to be adjustable or programmable for different parts/configuarations if possible.
RE: Thread Detection
please be more specific, what size threads are you trying to detect.
what is the specific end product
regards,
afterhrs
The parts are almost exclusively carbon steel and are typically less than 20mm thick. The holes to be tapped are typically less than 10 mm in diameter and are thru-holes (Internal machine threads). The part if for a large engine and lays flat on conveyors through grinding/deburr, wash/corrosion inhibit etc.
I hope this helps.
check out General Inspection's web site
www.geninsp.com
regards,
afterhrs
I believe that there are a few companies offering Eddy current inspection equipment in all different states of assembly from component to turn-key solutions. We have been dealing with SE Systems in Califonia.
Here is his contact information:
Geoff King
SE Systems, Inc
(510) 723-6006 (V)
(510) 784-0810 (F)
I believe they have a website as well.
A.J.
We currently have a Vision System running in a couple plants that detect threads very well. We are using a Cognex InSight 1000, with LED Lighting. If you have any questions, feel free to contact me.
Shawn Davidson
Radix Controls
(519) 737-1012 ext.335
http://www.eagledesigninc.com/etv.htm
David Baird
mrbaird@hotmail.com
Sr Controls Engineer
EET degree.
Journeyman Electrician.
In the past I have used Pico Dot lasers from Banner for this. In the last 3 projects Ive done for thread detection I have used the new Keyence LV-H32 series laser with great results. At a 30 degree angle to the threaded hole Im able to adjust the spot beam to cover 6 to 8 threads and have a lot of ajustability in the amplifier.
http://www.keyence.com/products/sensors/lv/lv_h32.html?links=4:M:T
Bob
Are you running the same part all the time or different parts. I have had some issues with "teachability" factor and operators. This would not be an issue if you are running the same parts all the time.
Afterhrs
Bob
I am curious to see how you rate the Banner pico dot,
from a reliability and accuracy stand point. I am getting ready to replace an outdated unit and the pico dot has been
given some consideration for this application.
Thank you,
Afterhrs
I just like the adjustability control I have with the new Keyence amplifiers.
Bob
NDT Technologies inc
1838 E. Highwood Rd
Pontiac MI 48340
248-332-0709
www.ndttechinc.com
If you go this route, I'd be curious if it works.
Email is a stealth email to minimize spam. Contact me & I'll get back in touch with you.
TygerDawg
