offset & erase all in one button
Ok here is a dosie
I am doing a lot of offsets at a given distance and then erasing what I had offset just to use with the trim command so some think like this
Offset line 1" then erase original and trim a line to the new line
So how can I set it so that the original gets erased after the offset I have tried the select command but as we all know offset expects only one object at a time and does not like previous select
What I have tried so far was a button macro like this
^C^Cselect;\;offset;1";p;\;_erase;p;
But because of the fault with the offset command it wont work if anyone has an idea like partial lisp in my macro it would be very much appreciated
if everyone helps everybody the world will be a better place
RE: offset & erase all in one button
hey does anyone think this might work if i create a button to do this
1 create a layer called trim then start the offset command and what ever i offset it putes it on the trim layer then i set it up so that when i start the trim command it selects everything on the trim layer and then when im finished trimming it erases everything on thetrim layer does this make sense
Place the following in a file called OSNTR.LSP
(defun C:OFFSETNTRIM()
 (setq oce (getvar "cmdecho"))
 (setvar "cmdecho" 1)
 (setq a (car (entsel)))
 (command "_.offset" pause a pause "")
 (entdel a)
 (command "_.trim" (entlast)"")
 (setvar "cmdecho" oce)
Create a button and assign the following macro:
^C^C(if (not C:OFFSETNTRIM)(load "OSNTR")) OFFSETNTRIM
Now ain't that nice.......
ok Stiker somethings wrong
Command:
OFFSETNTRIM
Select object:
_.offset
Specify offset distance or [Through] <0'-1 1/2">:
Select object to offset or <exit>:
if you press enter it cancles the command hmmm
what does it do exactly (or supposed to do)
>Command:
>OFFSETNTRIM
>Select object:
>_.offset
At this point you specify the offset distance or just press enter
Now select the object to offset
The object you offset will now highlight and you will be prompted to trim objects that cross the offset line. Also the original line you offset will be erased.
Offset a line you select at a distance you select, then enter the trim command to allow you to trim to it, and erase the original line.  (see your first post)
they dont highlight for me striker
as soon as i hit enter it canceles out of the command
why not the move command?
turn on ortho -f8
type "m" ,  select lines, enter
start to drag in direction desired, then type distance and enter. there is no line left to erase! just move the line!
good luck!
I have tested the original posted function in R12, R14, A2K, and A2002 with no problems. I cannot understand where you are having a problem.
OFFSETNTRIM
Select object:
Now select the object to offset, If you press enter the command will quit. You have to select the object to offset AND the direction to offset just as if you had selected the offset command.
Select object to trim:
Now you select the objects that cross the offset object to trim.
I don't think I can explain it any better
