C4 (84-96) Corvette Uprights (knuckles)
The Corvette C4 uprights are made of forged aluminum and will package inside of a 17" wheel to minimize scrub radius. They also have the benefit of using a sealed hub assembly that bolts in. I am thinking of using them on a future race car suspension. This is obviously not a novel idea so I was thinking that someone out there may have accurate measurements on ball joint locations, steering arm pivot, king pin angle, or even an accurate CAD drawing. If so, please leave a post. Thanks.
-Joest
-Joest
RE: C4 (84-96) Corvette Uprights (knuckles)
MarkEE
With the introduction of the C5 Corvette, GM allowed several Technical Documents to be published and presented at the 1997 SAE Congress. There may references to the information you seek in these documents as there are comparisons to the C4 parameters in many of them, as I remember. Here are links to the documents:
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
Also has the advantage of letting vendors charge well over $200 for the wheel bearings for one wheel.
"The next thing I'm going to try is purchase the Corvette Black Book 1953 - 2004 by Mike Antonick that just came out for the C5. ....
MarkEE"
MarkEE, it's an interesting book if you are a
Corvette fan, but don't expect to find any useful suspension oinformation in it. It's not there.
