Well your answers have eliminated several possiblities, so the focus needs to be narrowed down to the filler metal and it's heat treatment.
If possible, get a chemical analysis of your deposited filler metal just to make sure nothing is awry there. Some additional helpful information would be to perform a ferrite check on the weld. If it is significantly different than predicted by the WRC diagram, it would be further indication of intermetallic phases, usually sigma. Although I have more experience (i.e. welding procedures that failed the first time) with 2507 type duplex (ASTM A890 Gr. 5A), the same kind of principles apply. If you are going to try the test again, a couple of suggestions are to hold the 2050F a little longer. If there was significant sigma that formed during heating, or during welding, it may take longer than 2 hours to dissolve. 4 hours should be enough for a thin plate. I think a more likely culprit is the 1900F step cooling. I have done welding tests where a weld cooled from 2075F and held at about 1950F for 8 hours wouldn't pass bend tests(and had bad charpy values), but one held for just 2 hours bent fine. This was due to intermetallics. I have also seen it reported in literature that some high moly stainless steels can have intermetallic phases form at temperatures above 1900F.
Since the 1900F step cool is designed to keep the yield strength up, (Quenching from 2050F would result in low yield), see if you can raise it to 1925F or 1950F and live with the possiblity of a slight yield strength reduction. If my memory serves me, ASTM has 1900F as a minimum only, no max? Also try and keep it as short as possible based on the needs of the casting you will be welding.
With a 1" thick plate, quenching is probably not a main issue, but if you can get a better quech by agitating with propellers, or making sure the water doesn't get too hot, that may help also.
