Unhide components in assemblies
Anyone know of a quick easy way to unhide all hidden components in an assembly apart from manually scrolling down the tree and picking?
The Advanced hide/show feature seems too indepth for a simple 'unblank all' as in often found in other CAD packages.
RE: Unhide components in assemblies
when you mark the assembly you can select in the menue edit - show with dependents - this configuration. all components in the assembly or subassembly will unhide.
Thanks kikacop!
How about click the first feature, and shift-click the last, right click and choose unhide?  This is a Windows  application, so it should work (and I think I have done it before).  It might depend on the state of the last feature or the majority..........  Tweak with it a bit.
I was - and he did. So at least I didn't get coal.....
OK, OK, It's a reference to my holiday sig. "Be naughty - Save Santa a trip..."
