can AFM characterize surface with micron-sized features
My sample surface is featured with microspheres (0.3um-1.5um). Can I use AFM to characterize the surface? I know AFM is very good for nano-topography but not sure with my case. I have tried to use AFM with my sample one time. But the singal is very bad. Since I am a new user of AFM, I am not skillful operator. So I can't draw the conclusion that AFM is not good for micron-featured surface. Does somebody have any idea if AFM can do it? Or I need turn to other equipment to characterize and visulize my surface topography?
Thank you in advance if you would like to share your opinion with me.
RE: can AFM characterize surface with micron-sized features
Also if your sample is metallic, you may be able to use high voltage with extremely high magnification.
hope this helps
nick
You should be looking at non-contact surface profilometers; or SEM as suggested, with low voltages, since I'd guess that your microsperes are latex or something similar. You might still need to deposit a thin gold film if your SEM can't throttle down its beam enough.
TTFN
