proof rolling and "pumping" questions
I'm wandering if only an experience person can determine if "proof rolling" on subgrade material is satisfactory. I have observed rolling operations before, but just became familiar with the term.
I now that some deflection of the soil will occur just from great weight of the roller, but how do you know when deflection is excessive or if the subgrade is unstable? Are there any limits on the vertical deflection. The way I understand it is that some deflection is allowable, but "folding" of the material in front of the roller is not acceptable. Additionally, at the edges (sides) of the roller, ruts will sometimes occur. Are these ruts acceptable or should they be eliminated totally? If they are acceptable, how deep is too deep? Thanks for any clarity on the subject.
If you want to continue on the subject, what is the main reason for "pumping" of the soil when either a roller or the tires of a loader are passed over the area. Is it because the soil is above its optimum moisture content, or are there other reasons? Also, lets say that "pumping" is occuring at the highest lift of soil as it is being rolled. How can you tell which lift is causing the "pumping"--that is, if there is unsound material below the current lift, then how do you decifer if it is the upper lift or the lower lift that is causing the pumping? Thanks again for any clarity on this too.
RE: proof rolling and "pumping" questions
The soil type will have a large influence on the amount and appearance of 'pumping'. Some soils, such as silt, very fine sands and silty clays are very sensitive and can be quickly overworked. Sometimes these soils have a nearby watertable, the soils have been overworked and just require no compactive effort for a period of time and will 'heal'. In this case of a nearby watertable, immediate reworking the upper soils will not result in any improvement.
Proof Rolling always requires 'local calibration' and several 'knowns'. The location of the water table will determine whether large amounts of subgrade rolling (pumping) are due to deeper subgrade problems or to a wet, near surface layer. Each situation may require very different responses.
Actual rutting during the final stages of fill placement is generally not acceptable but, the final use will govern how much instability can be tolerated. I often times use a preliminary proof rolling to recommend the amount of soil improvement (Structural Fill Thickness, use of Geofabrics and/or Geogrids). Final proofrolling oftentimes results in deflections and sometimes very minor rutting of less than 1/2 inch. I have been on some projects, with very high ground water tables, in which rutting up to 1-1/2 inches was still acceptable.
I am sure that others in this forum will have more to add, based upon a wide range of experiences.
