Sizing criteria for reciprocating compressor piping
Does anyone have specific guidelines or references for maximum velocities that should be used when sizing the process piping on recip's. I have a very non specific reference that states the piping should be sized for a maximum velocity of 12m/s.
thanks
thanks
RE: Sizing criteria for reciprocating compressor piping
I then check the unit pressure loss and adjust the line size to get 0.25 to 0.5 psi/100 LF.
The above procedure most likely will give you a velocity higher than 12 m/s. Don't know any justification for this low a velocity unless your pulsation analysis warrants it to limit the forces in elbows, etc. although I have never experienced this problem following the above.
Another approach is to size the piping pressure loss to be equal to the allowable peak-to-peak pulsation pressure.
If noise is a problem then insulate the piping.
By the way, the bypass line size is typically half the suction line size.
Consider API 14E which limits velocities to 60 feet per second - for noise control.
Consider too, limiting pressure drop in suction piping to 1/4 psi per 100 feet, and in discharge piping to 1/2 psi per 100 feet.
it is best to have a pulsation study/analysis accomplished during the design in which the entire system design (i.e. compressor details + piping arrangement, etc.) are addressed.
-pmover
