Drawing Sheet Number Change Mess Up Print Range
Hello:
I have a large drawing whith 20 sheets. I have problem knowing what is the page number when I want to print out using print range.
Pages=Original sheet name=Renamed to
1____=Sheet 2______= Banana
2____=Sheet 3______= Cherry
3____=Sheet 1______= Apple
4____=Sheet 4______= Dewberry
the original sheets have been renamed and reordered
Using the example above if I want to print out Apple to Dewberry I have to look at the Feature Manager and count the names to know what I want is for page 3 to 4 in the print range to print out.
Is there a way to find out the actual page number of the sheets without the need to actually count it.
RE: Drawing Sheet Number Change Mess Up Print Range
I was - and he did. So at least I didn't get coal.....
CorBlimeyLimey
Barrie, Ontario
FAQ559-863
If I re-arrange the order of the sheets, then I have to manually change the name in "Sheet Properties".
The border has text that shows "Sheet 4 of 25" for example.
The "4" in "Sheet 4 of 25" is:
CODE
CODE
I hope there is an easier way than to edit each individual name in Sheet Properites.
Flores
