SW2004 BOM & Revision Table Column Widths
I've just started using 2004 and creating a new drawing sheet format for our company. We currently just have SP 0.0. Is it possible to shorten the width of the columns in the BOM and Revision tables? For example, my REV. column is about 5 times longer than needed. I know how to adjust it, but it stops at this minimum width, which is not minimum enough.
Also, concerning the date that is auto-entered in teh Rev table when a revision is added, can the user change the format that is used. My default is 1/13/04, we use 13JAN04. Can that be changed?
RE: SW2004 BOM & Revision Table Column Widths
Can't help with the date issue though.
Is this resolved in sp1?
You can do the same by RMB the column and click on Formating. That gives you Column Width. You can change it there to but you will not be able to go below a certain size. Which is dependent on the text size.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
