D2 Tool Steel v ALZ H13 Steel
I have been with a company for 5 weeks now and I have to order some Bending Tools. Bar is heated by induction and then bent around a radius.
The drawing I have for these radiused tools state the material is D2 Tool Steel but other drawings state ALZ H13
Both sets of drawings request Hardening to 54-56 Rockwell C.
As many engineers have left and Im now the main man I cannot find any records of why some were ordered in D2 and some ordered (at a later date) in ALZ.
Im guessing ALZ was offered, and taken, as an alternative to D2 but I hoping for some advice / URLs regarding the 2 materials (price comp. / use comp. etc)
TIA
TIA
Milkboy
RE: D2 Tool Steel v ALZ H13 Steel
Nick
I love materials science!
At the risk of sounding naive, the material the tools will bend is SAE15B 35H, heated by induction to glowing red, so Im pretty sure thats well over 540°
When you say 'important' Im reading between the lines here in thinking the ALZ is better at 540 and above than D2
TIA
Milkboy
the actual temperature of the material being formed/bent is usually not so important. What is important is the temperature that the tool itself is going to reach. Some tools that cut high temperature materials are cooled and have minimal contact time with the material being cut. The hardness levels you are talking about are low for D2 type material and from memory about average for H13. My guess would be your company will have used both D2 and H13 for this application. Out of interest what is the reason for failure on the tooling ?
Richard
The tooling has not failed as such we just require
more tooling and tool holders to reduce time in changing
tools and building cetain width.
My confusion comes from the drawings which call D2 and ALZ
and the fact the guy who did this last time has left !
I have actually started a thread about the TOOL HOLDER
material in Eng Tips. This is called up as FORK STEEL on the drawing and ex-employee probably knew what it actually was.
Any suggestion as to a good tool holder material ??
TIA
Milkboy
ALZ H13 is just a brand name from a tool steel stockist in the UK it is standard H13 material.
As already mentioned D2 is a cold work steel whereas H13 is a standard hot work steel. In some markets D2 is more expensive in others H13.
Not much help im afraid. If youd like our data sheets on H13/WNR. 1.2344 or D2/WNR. 1.2379 I could mail these to you.
Richard
literally seconds ago
In the past EN24T has been used as a tool holder
It think Ill go with this (??)
Milkboy
