ASME UG45 Nozzle thickness when connected to flat plate
Can someone explain if the nozzle thickness when connected to a flat plate acc. UG-45(b)(1) should have the thickness of the plate? Isn't a smaller nozzle thickness allowed?
RE: ASME UG45 Nozzle thickness when connected to flat plate
prex
http://www.xcalcs.com
Online tools for structural design
Make sure you read the entire paragraph.
