Silo Foundation Overturning
If seismic overturning is based on the live load (bulk storage) in the tank, should the live load be used to assist in resisting the seismic overturning?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Silo Foundation Overturning
The amount of product that may be used to resist seismic overturning is entirely depended upon the details of construction.
If the silo is tower or skirt supported, then all of the product that is present will resist overturning.
If it is a ground supported silo, its more complicated. For an unanchored silo, the amount of uplift resistance from the product will depend on the thickness, material strength and details of construction of the silo bottom at the shell-to-bottom joint. If the silo is anchored, the uplift resistance of the silo wall will not include any product component and will be entirely dependent on the anchorage details.
In addition, the foundation design will also govern. If its a solid slab, you may be able to count all of the product. If its just a ringwall foundation, you will not be able to assume all of the product is effective.
Unfortunately, it's one of those "depends" answers. More info would be need to provide proper guidance.
Hope this gets you started.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
That's helpful. The tank is skirt supported with a slab foundation. The thickness of which will be dependant upon how much material I can include in resisting overturning. Which from your post, I can use the entire weight of the material. This is what I was assuming in the preliminary design, but wanted to get some other opinions.
Can you elaborate on why only some of the material weight can be accounted for in a ringwall type foundation?
Imagine this situation. A flat bottom silo for granular produst storage is anchored to a ringwall. The unit uplift seismic force (lbf/foot) in the silo wall exceeds the unit weight of the silo roof, wall and the foundation. Upon uplift, the ringwall will pick up part of the granular product that is situated directly over the inner portion of the ringwall. In addition, a "wedge" of product will also be picked up... how much will despend upon the internal friction factor, angle of repose, etc. Yes, the seismic activity may cause some product shifting, so therefore, you may wish to count only the product directly over the wall. Hope this helps.
Steve Braune
Check out Thread507-78481 you may find some very useful information.
