Hole wizard Bug
Hole wizard Bug
The hole wizard, in assemblies has a bit of a scary error. The hole series function gives a tapped hole one size too big, for the clearence holes (if you use automatic hole size selection). This problem exists for metric holes, I have not tested it for imperial.
