finishing options for aluminum
Hi All,
What are the finishing options for aluminum part with blasted surface finish? I'm looking for some kind of coatings/platings/... which can protect the part from stains/scratches and normal cleaning agents. I also need to keep the natural aluminum color (dull silver look), so I guess some kind of clear coating or silver color plating will be fine.
I am designing an aluminum part which will be manufactured by either investment casting or die cast. It will be sandblasted. However, after handling the part for a while, fingerprint stains were all over the part surface and they are not easy to remove.
thanks,
lee
RE: finishing options for aluminum
There are various anodization coatings that can do this job.   You should check with a metal finisher.
TTFN
In addition to anodizing, you can investigate organic coatings.  For example, aluminium alloy wheels for automobiles have a clear acrylic powder coating applied to them.  Try Dupont, BASF, and PPG.
Cory
Clear coating over anodize will give the best protection.  Alcoa has been selling Dura-Bright® aluminum wheels for commercial vehicles since 1994.  From the description and illustration on their website http://www.dontpolish.com/technology_2.shtml?08, it appears to consist of a buffed finish (brushed is optional) protected by a clear anodize layer and a top layer of clearcoat.
Alcoa also markets (what appears to be) a similarly coated Dura-Flange™ wheel for applications where loads are heavy and prone to shifting, causing tire walls to rub against the wheel rims.
http://www.alcoa.com/alcoawheels/en/news/news_release/f...
