Automatic assembly
Automatic assembly
Hello there my problem is that I am on the beggining of project for automati assembly same parts. There between this parts is spring. I dont have idea which way I must find becouse the spring is very hard to sepatate from group. Is there some robots ore some air presure for this problem. Is there some company with this answer. Please help me . Thank you.
RE: Automatic assembly
I think you are looking for a spring detangler. The above link should get you started. It does a great job with closed end springs. I am using one of them on a new machine at my company. You might want to build some type of rotory transfer machine. Hope this info helps
Robert Setree
www.advanced-grinding.com
