Initial setting on SW
I just installed SW on me new computer. Some of the things I grew used to in my old installation are: automatic updating of parts within an assy, vis. If you make changes to a part it is automatically brought into the assy the next time you open it.  This went away in my new installation and I want it back, How?
David A. Johnson
Thunder Systems Inc.
Corona, CA
RE: Initial setting on SW
What version of SW has been installed?
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Go to Tools->Options and reset the options you want.  There may a way to transfer the settings by exporting a registry setting, but I hear that sort of thing is flaky at best.
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
SW 2003 SP 5.1
David A. Johnson
Corona, CA
The only thing that comes to mind now is...
System Options>Drawings> enable "Allow auto-update when opening drawings".
After you open an assy, can you Crtl-Q and will the changed parts appear/update?
Ray Reynolds
Went out of dwg and came back in, problem went away.  I thought I'd tried that before. Sorry
David A. Johnson
Corona, CA
