Steel Making? Problem
I want some information about the problem that should be cosidered in steel making. (Coils for Pipes)
How do we improve the quality of the steel plates
what is the problem that should be cosidered if we are buying steel from steel makers?
I want to know the failure and the defect that may appear in the steel during the making process...specialy the one that cant be find?
RE: Steel Making? Problem
You could als try the AISI (American Iron and Steel Institute) at www.Steel.org They have a good website with links to most manufacturers and related sites.
Good Luck.
Defects in plate can come from cracking but the most likely cause of problems is inclusions which arise during casting. These can be ductile or non ductile and dependant upon the end use can change the requirements. Non ductile inclusions can perpetrate cracks when futher processing is applied and for plate grades this will be your main area of concern.
nick
Nick
I love materials science!
