Text on round stock
Text on round stock
Text on round stock
How do you put text on  1.oo round stock so the text follows the curve.thanks Castingman
RE: Text on round stock
Start a sketch.  Then select Tools, Sketch Tools, Text.  You can select the edge of the round stock or create a sketch for the text to follow.  If you go under Help, under the index tab type text and then select sketch it shows an example.
BBJT CSWP
In SW2004 you can do the text sketch then the "wrap" command. Works really well.
