Template Settings
Template Settings
We're just getting started with SolidWorks and as I configure Part, Drawing and Assembly Templates I want to printout the values I've set, such as spin increments, fonts type and size for annotations,etc.
Is there a method or add on I can use to do this?
RE: Template Settings
You could do a "screen capture" of the various dialogue boxes & print it though.
CorBlimeyLimey
Barrie, Ontario
FAQ559-863
CorBlimeyLimey
Barrie, Ontario
FAQ559-863
As for the spin increments you can just type that information in and use screen captures pointing out what goes where in the tools\options menus.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
http://swtools.cad.de/download.htm
Just grab the 'Copy Drawing Options.' (It also works with part options, assembly options, and system options.)
This is actually an Excel Spreadsheet that uses an Excel macro to copy, store, and set the options in SWX documents (also does SWX system options).
