problem with "View Mates"
We have 4 seats of SW at work and 3 of us expierence this problem (4th person doesn't draw that much) I also have the same problem when using SW working at home.
In our assy's (after they get some size) if you right click a part in the assy to view mates, it will work usally once or maybe twice then from then on, it will show you the mates for that particular part, but if you try to select one to modify or delete, etc., there will be a graphical error and the Property manager tree will just partially appear right in the mate text. It always shows the question mark from the PMT which should be under it. After that, you are done with view mates and have to sort thru hundreds of mates to find the one you want.
we run SW 2003, I have at home a Intel P4, 2.4 ghz, 1.0 gig ram, 256 mb video card, and still have the problem.
at work I have a Intel P4, 1.8 ghz, 1.5 gig ram, 64 meg video card.
I just checked my current assy and it has 27 sub-assys in it 377 total files in the main folder, main folder size= 133 MB.
Any help or thoughts on this?
Ken
RE: problem with "View Mates"
RipV,
First guess would be the video card. You say at home you have a 256mb, and at work a 64mb one. You don't say what video cards they are, but nVidias Quadros are the favorite of a lot of folks, and SW it seems.
Do you have the latest drivers that are approved for SW use? You can check on their website for more info. If the card is fairly old, and you have never updated the drivers, that might be the place to look first...
Mr. Pickles
Mr. P,
I waited till Mon A.M. till I got to work to get the correct Video Card #'s from work.
My home card is a XFX GeForce FX 5200 256 mb
My work card is a 3D Labs Oxygen GVX1 32 mb
My 2 co-workers have a Nvidia GeForce2 MX 64 mb
All 4 machines experience this problem. As far a my home unit goes,I did research cards a good bit prior to purchasing my computer. I got such a good deal on the package with the above card included that I thought I would try it 1st rather that spend the extra $$. Other than this particular problem it has been flawless in SW and everything else.
Ken
We had the same problem too on 2003 and our cards were approved by SWorks , Oxygen VX1 32Mb.
The only thing I found was to close the file and re-open it. Sometimes the mates would also show grey as if suppressed when in fact they were not.
I havent personally had this problem with SW2004 but having said that.. for each bug that they clear.. another 2 or 3 jump in!
Wow, that is really a cool way of looking at mates. I learned something new today. We are also using SolidWorks 2003 SP5.1 My Video Accelerator is ATI FireGL2. Your method worked for over 20 right mouse clicks on different parts. A work around for you maybe the old way I have been looking at mates, before this new way. Click View in main SolidWorks menu, then FeatureManager Tree button, and then view By Dependencies.
That is a lot of mouse clicks, so I programmed them to the macro keys Shift F for features and Shift D for dependencies.
If these test, does not work it maybe the video cards.
Good luck to you.
Bradley
You might know this already but...
GeForce FX 5900\5600\5200
 Win2K  6.14.10.4403  08/28/2003 2004  View Notes
 WinXP  6.14.10.4403  08/28/2003 2004  View Notes
 Win2K  6.14.10.4403  10/01/2003 2003  View Notes
 WinXP  6.14.10.4403  10/01/2003 2003  View Notes
All these cards are a pass with limitations. This can't be ruled out.
GeForce 2 GTS/MX
 NT4  4.0.1381.532  10/02/2002 2004  View Notes Pass
 Win2K  5.12.01.0631  06/19/2002 2004  View Notes
 NT4  4.0.1381.532  10/02/2002 2003  View Notes Pass
 Win2K  5.12.01.0631  06/19/2002 2003  View Notes
 NT4  4.0.1381.532  10/02/2002 2001Plus  View Notes Pass
 Win2K  5.12.01.0631  12/19/2000 2001Plus  View Notes
The rest are Pass with limitations. This can't be ruled out either.
GVX1
 NT4  2.16-0866  07/28/2003 2004
 Win2K  2.16-0849  07/28/2003 2004
 WinXP  2.16-0849  07/28/2003 2004
 NT4  2.16-0866  06/28/2002 2003
 Win2K  2.16-0849  06/28/2002 2003
 WinXP  2.16-0849  06/28/2002 2003
 NT4  2.16-0866  03/28/2002 2001Plus
 Win2K  2.16-0849  03/28/2002 2001Plus
 NT4  2.16-0388  12/11/2000 2001Plus
 Win2K  2.16-0421  12/11/2000 2001Plus
 WinXP  2.16-0849  03/28/2002 2001Plus
These all pass.
Make sure you have the approved Video driver for the passing card(s).
Be sure your using the latest SP. There was a problem like this in early SP's of SW03. But only a selected few ever seen this problem. I think it was a limitation between certain video cards. I say that because I could never recreate it on any of my workstations, but others in the company could.
The Oxygen cards are a few years old and their drivers are too... last I checked. So I'm not sure what to say about that other than that one person I know that recreated the problem was also using an older type of card (Elsa Gloria II) and he too could re-create this problem. I was thinking later SP of SW03 fixed this problem. If your not using the lasted you could always try it out.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Thanks for the input. I bet it's the glitch in the early 2003 SP. Also I failed to mention that at home I run XP Pro and at work we have Win NT SP4
RufusUK,
its comforting to know others have experienced it too
(I think) actually its not :)
Bradley,
Sounds like we each learned something today. I didn't know how to do it your way either. I like mine better, but if it don't work...then go to plan B I guess.
SBaugh,
Thanks for the info on the cards etc. I have emailed this to my boss. Hopefully they will spend some $$ and do something. My drawing is running slow enough that it takes a good 8 minutes to just save it.
As for home use, I think I will live with it for now as I only do that occasionally.
Great forum by the way,
Ken
also I just checked, I/we are running SP0, right out of the box.
You problem is most likely related to video card/OpenGL compatibility.  The key seems to be "after you have been running for a while.."  There was a lot of it about in those days.  The later SP may fix it, but if not you will have to get a new graphics card or updated driver that will handle the "unified back buffer... thingamigig". It was very frustraing for us as we had someone check out that rev with some new boards, but they did not get to the magic combination of part size and time.  So we had to send them back and went to Quadro's.
I was - and he did. So at least I didn't get coal.....
