Problem: Alphabetizing Layers in "Layer Prop" Dialog Box
Hey everyone,
New to EngTips - first post, so bear with me.
We are still running v14 and have a problem with the layer list in the "Layer & Linetype Properties" dialog box ("layer" command).
After inserting an x-ref into a drawing, the layers in the "Layer & Linetype Prop." dialog box come up scrambled—that is, not alphabetized. Doesn't happen with all drawings, so must have something to do with the contents of particular x-ref'd drawings that causes AutoCAD to forget how to order layers in the dialog box. Also happens with the "Layer" button in the "Modify Properties" (DDmodify) dialog box. I know you can alphabetize the contents of a dialog box column using the bar at the top of the column, but we're trying to minimize steps—this should happen automatically.
No one in our office has come up with a fix? Any of you guys have an idea what causes the scrambling of a dialog box or how to fix it so they automatically arrange themselves?
Thanks in advance,
EngTech2
Thanks in advance,
EngTech2
RE: Problem: Alphabetizing Layers in "Layer Prop" Dialog Box
no combination of system variables could make the layers scrambled: not VISRETAIN, XLOADCTL, INDEXCTL), no option in the File>Save As> dialog box, No option under Tools>Preferences> Performence Tab -->Ext. ref. file > Demand Load/Enabled.
Are you sure the layers are really scrambled?
layers wouldnt rearange properly and there a few other quirky things i dont remeber off hand but give this a try
1st do you know anyone that has 2000 if so get them to run recover on one of your drawings then save back see what happens then if that doesnt help at all look at what you may have running in the background with autocad cause anything even the simplest programs have been known to cause problems here and there if a virus scanner is running disable it they will cause a lot of problems
now after that try creating a new drawing see how the layers in it reacts then if still a problem i can suggest a few other things but try all of these first
if everyone helps everybody the world will be a better place
MAXSORT it is!! I just cheked out.
When number of something in a dialogbox listing exceeds MAXSORT value, they are not sorted - appear in the order of creation - like layer 100something follows 99something.
Goes for block names, layer names, maybe linetypes and other such symbol names too.
Striker really earned this star. Here it is.
but maxsort did aleviate the other problem
EngTech2
