Flushing oil requirements
Hi there!
Is there any design criteria for determining flushing oil requirements for equipment (i.e., flow rate)?
Any help is well appreciated.
RE: Flushing oil requirements
The equipment manufactuer usually specifies the hot oil flush requirements for the piping external to the unit.
By the way, I would recommend that you get a speciality contractor to do the work. They have the equipment to do the flushing and the meters necessary to measure the cleaness level.
