Solid density error using UG mass3d function in excel
Hi All,
I was wondering if anyone has come across the following issue. I have a tabular note in my drawing which shows the Mass of each of the solids in my part which was made using separate feature densities. It was working fine even with UG bugs and gave me the proper info.
Now one of my solids which has a name attribute used in mass3d has lost associativity to the Solid Body, when I get Object info or do mass props and pick the body I'm given the proper information.
The only thing that changed in my work part was that I assembled a Master Model component. Could this have anything to do with the excel error?
Please let me know if you have seen this error.
Thank you,
Michael
