Barske Impeller
Barske Impeller
I'm looking for design information on Barske (I've seen it written "Baske") type impellers. These are open, straight vaned impellers that are suited to low (less than 1,000)specific speed applications.
I've found a couple of companies on the web that will design it for me, but I need to learn how myself.
RE: Barske Impeller
Specialized industries such as automotive often use this kind of equipment, efficiencies are low but power and efficiency are low on the list of priorities.
PUMPDESIGNER
RE: Barske Impeller
RE: Barske Impeller
From my experience, the efficiencies are much (if at all) of an improvement over higher specific speed centrifugals that hit the same performance... but it does help with non-overaloading requirements of the driver (shorter curve). Some specs call for a pump to be sized within a percentage of BEP and this type of pump could help.
Sundyne makes straight vane impellers, but they are very small, very high speed designs (15,000 rpm for ex.). Highly machined parts. At the other extreme, I've seen straight vane impellers on March mag drives. I don't expect either to be what your after.
Stepanoff and Karassik don't cover it. You'd likely have to get experience with a manufacturer to learn some of the key aspects. But the basic princicles still appply to all centrifugals...just don't expect high efficiencies.
RE: Barske Impeller
As stated above the Barske (also written as Barski)impeller is one of the two keys to low flow / high head pump design. The other important ingredient is a concentric casing (rather than eccentric with a cutwater). This allows liquid to stay in the casing for more than one revolution around the casing, without the associated recirculation difficulties of cutwater / volute designs. It results in the ability to bleed off some of the high velocity liquid (converting to pressure in the rapidly expanding discharge volute).
Because of the relatively low efficiencies of this design, one should look closely at the effect of temperature rise of the fluid.
Hope this adds something to the thread.
Richard
RE: Barske Impeller
RE: Barske Impeller
RE: Barske Impeller
