Anti poly styrene sulfonic acid additive for coatings
Dear Sir ,
We are searching for a additive for PVA (Poly Vinyl Alcohol) water born film which will make this film stabile in presence of poly styrene sulfonic acid.
Thank you in advance.
Zlatomir
Zlatomir
RE: Anti poly styrene sulfonic acid additive for coatings
In searching the Internet, I found that PVA and coplymers, e.g., poly (ethylene + vinyl alcohol) is sometimes layered between polyethylene. The PE+VA copolymer is a gaseous diffusion barrier, while the PE outer layers are moisture and chemically resistant.
It is possible that the makers of PVA sponges may have a modified PVA formula: http://www.ceibatech.com/AIONMain.htm
An internet search of "crosslink PVA" should provide other leads. Manufacturers of PVA emulsions may have some suggestions.
DuPont manufactures one type of product to crosslink PVA. http://www.dupont.com/tyzor/
Other suppliers: Kenrich or Johnson-Matthey catalysts businesses
