Member Login
HANDLE
PASSWORD
Remember Me
Forgot Password?
  • Turn Off Ad Banners
E-mail*
Handle
Password
Verify P'word
Partner With Us!
Partner Button
(Download This Button Today!)
Member Feedback
"...A lot of the information I've found at this site would've taken me forever if I'd have attempted to research it on my own. Thanks again."
Geography
yates (Aerospace)
9 Jan 04 3:15
I would like some feedback from fastener manufacturers on the following points concerning (external) thread gaging :
- Has anyone experienced different results (i.e. same thread being conform or not conform) when using a) standard ring gage, b) adjustable ring gage c) roller type snap gage (functional) d)segment type snap gage (functional) ?
- Any ideas on the reasons for the differences above (assuming all gages are satifactorily in calibration ?
- How do you deal with a customer who throws out your bolt because he didn't find it conform with a different (but legal) gaging method than the manufacturer ?
Eng-Tips Forums is Member Supported. Click Here to donate.
Helpful Member!BillPSU (Industrial)
15 Jan 04 2:16
Different gaging methods can give different results. Thread ring gage shows the thread is correct however the first thread may be the only thread large enough to stop the no-go gage. when a thread snap gage is used it is used in the middle of the thread and the PD in the middle may differ from the end. Thread form variation may also be a problem.
All thread ring gages are adjustable and are set with a setting master.
Thread gages are a composite gage trying to cover several different features (PD and form) at the same time and even if the PD of the thread is correct the major diameter may still be in error.
Talk to your customer and find out what method of checking they are using and if their gages have been calibrated and check your parts with the same method if possible.
MechEng13 (Mechanical)
15 Jan 04 7:14
A Star for that BillPSU.
At my last employer, thread rings were often problematic for accepting/rejecting parts, between ourselves and customers,and ourselves and vendors.  In many cases we had to end up supplying rings to the customers and receiving rings from the vendors, such that we were all checking the same way.
Alan M. Etzkorn
Product Engineer
Nixon Tool Co.
www.nixontool.com
diamondjim (Mechanical)
15 Jan 04 8:11
You might want to consider buying the
same type gages that the particular
customer is using if the quatity of
parts can justify the cost.
yates (Aerospace)
15 Jan 04 11:38
Thanks for your comments guys. No real correlation is possible with customers, however, since we sell same product to several customers. I would prefer gages (roller or segment types) which measure several threads 'cos, as pointed out by BillPSU, the first chewed-up thread may be the one stopping the bolt from going on a no-go gage. One remark though 'all thread ring gages are adjustable' ?? - we do not use these, only solid ring gages. The adjustable types tend to act like a thread die on soft (cad, silver...)
plating and chew it off.
In problem described above, all gages are new and certified as calibrated. The offset described between the two methods is always in the same direction which enables us to purposely roll threads for ring gage gaging or for functional type roller or segment gaging; The problem arises when several customers need this product. There does not appear to be a reference method.
Helpful Member!Helpful Member!Billybaru (Mechanical)
2 Feb 04 12:38
You might want to get a copy of ASME B1.3M ("Screw Thread gaging Systems for Dimensional Acceptability - Inch and Metric Screw Threads"). Have run across this problem in the past. Section 6 (b) in the ASME B1.3M contains a statement "Within each gaging system, a choice of gages is specified for each characteristic. Acceptance by any one gage specified for a characteristic shall be the criterion for acceptance of that characteristic." Showing your customer this spec may help in these situations.
yates (Aerospace)
5 Feb 04 5:39
Many thanks Billybaru, I KNEW I'd seen that somewhere.
Start A New Thread
Promoting, selling, recruiting and student posting
are not allowed in the forums.
Posting Policies
LINK TO THIS FORUM!
(Add Stickiness To Your Site By Linking To This Professionally Managed Technical Forum)
TITLE: Welding, Bonding & Fastener engineering Forum at Eng-Tips
URL: http://www.eng-tips.com/threadminder.cfm?pid=725
DESCRIPTION: Welding, Bonding & Fastener engineering technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden.
