Getting Autocad Dimension Data
Is there a way to extract the value of a acad dimension with some sort of getvar or getval?
RE: Getting Autocad Dimension Data
This function I did You can help You:
(defun get:value (/ dim-ent value)
(setq dim-ent (vlax-ename->vla-object
(car (entsel "\nSelect object dimension: "))
(if (vlax-property-available-p dim-ent "measurement")
(progn
(setq value (vlax-get-property dim-ent "measurement"))
(prompt (strcat "\nDimension value is: "
(rtos value 2 (getvar "dimdec"))
) ;_progn
(prompt
"\nThis object don't have this property. Try again..."
) ;_if
(princ)
) ;_defun
FORO: http://www.hispacad.com/foro
Un saludo de SpeedCAD... ;)
CHILE
