One-Way Supports
One-Way Supports
One-Way Supports
I was wondering if anyone knows a way to model a support that can only provide a reaction in one direction (i.e., restrained in -z, but free to move in +z)
RE: One-Way Supports
Ted, you will need to Define  and draw Link properties for GAP or Hook. You can can input stiffeness and opening
Yes, but how?
There may be another way to do it. Just put some dummy element with very high stiffness under the node. The lower node(s) of the dummy element should be restrained in Z direction. Not a perfect solution perhaps. But you will get quite satisfactory results.
