a custom button but no idea how to set up
well this is kinda a multi part question first im trying to set up a button to change a selected object to a set layer or the layer of another object
but the other question i have is what would be easier
a lsp that
offsets a lin 6" then shortens it by 1.5" on each end and setting it to a perticular layer
or a button that allows the person to do this one thing at a time
if everyone helps everybody the world will be a better place
RE: a custom button but no idea how to set up
ok so i have a button the macro is
^C^Cselect;\_offset;(offset distance needed);_change;p;p;la;(getvar(CLAYER));
the last part i think is what is not working maybe i have the sintax wrong coould some one give me a hand
im thinking instead of getvar it should be setvar there am i right
ok i figured it out yeaa i feel so much better it was
^C^Cselect;\_offset;(offset distance needed);_change;p;p;la;(getvar"CLAYER");
so now it works yeaa if someone sees somthing wrong even now let me know
well i spoke 2 soon works great with one object at a time but if i select multi objects it doesnt like it
i cant figure it out do i need to tell it to clear the selection set at the end of my macro
well it took me a few seconds but it was worth it here is the macro now
^C^Cselect;\;_change;p;;p;la;(getvar"CLAYER");;
it only changes the layer of the selected objects to the current layer im still working on getting it to do the offset
^C^Coffset;6";\\;_change;L;;p;la;(getvar"CLAYER");;
well here it is the real thing this time i think so far i can only get it to do 1 offset at a time cause the offset command looks for only one object at a time so picking a selection set wont work but if anone wants it there it is oh and if you want to know the macro for just changeing an object(s) to the current layer here it is tooo
^C^Cselect;\_change;P;;p;la;(getvar "clayer");;
