Electronic Assembly Standards for Toe Fillets
It is my understanding that per IPC specs toe fillets are not required as they do not add any strength to a solder connection. Our thoughts were allways that proper toe fillets are a sign of a good process. What are some of your guidelines and thoughts for inspecting toe fillets. How much importance do you place on proper toe fillets and what do you consider a proper toe fillet? Thanks.
