Line Reactors
Line Reactors
We need a few line reactors for use on top of VFDs.
We need them in 1-2 weeks, so inventory is important.
40hp and 10hp
480 volt 3 phase
Suggestions for reliable and knowledgeable vendors would be appreciated.
Although we have an electrical engineer he claims to know little, prefers to play with 3 volt chips-n-things, so we need to use vendor's expertise.
Thank you.
40hp and 10hp
480 volt 3 phase
Thank you.
PUMPDESIGNER
RE: Line Reactors
SEE: http://www.transcoil.com/
http://www.transcoil.com/#klr for KLR line side reactors
http://www.transcoil.com/#klc for KLC VFD Output Filters
jO
RE: Line Reactors
http://www.hammondpowersolutions.com/reactorprod.html
RE: Line Reactors
www.mtecorp.com
RE: Line Reactors
I have also had good luck with MTE.
Also be aware that some drives come are already equipped with line reactors, from what I am told, they also may be called "sine filters"
Best Regards,
Afterhrs
RE: Line Reactors
I have worked years past with Trans-Coil, good company.
Will check out the others because we are going to be purchasing them more and more.
PUMPDESIGNER
RE: Line Reactors
RE: Line Reactors
http://www.hitrancorp.com
http://www.squared.com
http://www.thomasregister.com
and type Drives: Adjustable Speed under Service or Product that will return 288 companies to approach to.
Etc. for more info
