Stronger steel than 4340......
I have a Ø6" shaft that necks down to Ø4.70" which is splined. The shaft is subjected to torsion and bending.The splined shaft goes through a cyclical bending as it rotates, and this eventually lead to the shaft breaking after a little over two years of operation. The shaft broke right at the point where the usable spline length ended. Basically the Major Ø of the spline is the Ø of the necked down portion of the shaft (Ø4.70). Torsional-wise the shaft can easily handle the torque, it is just over time the bending fatigued the shaft. Without getting into detailed analysis of the application, what class of steel would better handle the bending (give longer life). Assuming the operating parameters are the same as the previous shaft, (I can't guarantee the customer the shaft will last longer), what would be a better material? The current shaft is 4340 Q&T (don't know the details of the Q&T) to 269-321 BHN. The length of the spline was nitride case hardened to a depth of 0.015-0.020" and Rockwell 15N hardness 90 minimum. Thank you for your support.
RE: Stronger steel than 4340......
The tensile strength of the 4340 steel is what will predict longer or shorter life for the shaft. The case you describe is the perfect bending fatigue case. Looking up your hardness on my chart gives a tensile strength estimate of 140-150ksi. I see from www.matweb.com that higher hardness/tensile strengths are possible w/ this steel.
If higher tensile strength material is used you will have longer service life. However there are many other things to consider with this change. Some are: service temperature, shock loading, corrosion, SCC (not sure but usually as strength goes up this get easier), etc...
nick
300M is a steel grade based on 4340 with ~ 1.6% Si that enables higher strength for a given tempering temperature. Tensile strength can be in excess of 300 ksi (>2100 MPa). The standard for ordering this grade is SAE AMS 6419.
Another grade to consider is Aermet 100 from Carpenter. It is a very high strength grade that has been used to replace 4340 and 300M in demanding applications like aircraft landing gear. Typical properties are UTS = 285 ksi (1965 MPa), but since it has better fracture toughness than 4340 or 300M, it can be used at maximum strength even in notched conditions. This grade is referenced in standard SAE AMS 6532, and you can find more information at http:/www.cartech.com
However, you will likely obtain more significant improvements in fatigue life by investigating the following:
1. Reduction of stress concentration.
2. Improving surface finish.
3. Introduction of residual compressive stress (shot peening, laser shock peening, roller burnishing, Low Plasticity Burnishing, etc.)
How is the transition from the 6" to the 4.7" handled, is it stepped with a radius or is it a tapered transition?
Where is the stop off of the nitrided area in respect to the break? There might be a metallurgical notch at this point.
If you have a bending moment on the shaft can you use a more flexible design in the 6" shaft.
You might want to look at Astrally-V Bar for you shaft. You can contact the people at the following Url with the problem. We made a considerable number of our shafts from this material.
http://www.astralloy.com/index2.asp
You do not clearly identify if the cracking is rotational bending fatigue at the section change or torsional fatigue cracking initiating at the spline roots. It is important to make this identification as the solution to the problem will be different in each case.
In both cases it probably boils down to design rather than a metallurgical solution (apart from the benefits of shot peening).
However, do not lose sight of the basics - exotic materials are fine but sound design is essential! There TVP has it right again, the three pillars of fatigue resistance are there:-
- no sharp changes in section
- the best surface finish possible
- compressive stress (shot peening or fillet rolling on a cylindrical radius)
JS30B has been used for shafts of a similar size and can be supplied at a strength level of around 1200MPa (~170ksi) min yield, with 50-60 J (35-45FtLbs) RT impact (~388HBN).
Solution: Revise machining to a good surface finish, replace chamfer relief with radius, and through harden material. The hardening had the side benefit of allowing us to gun bore the center of the shaft for reduced rotating mass. Those shafts now have 3 years on them without a hiccup.
This is best done if a formal approach is desired in books that discuss 'Quality Planning' or chapter labeled as such.
I would guess it is the radius. It is known that such parts are very sensitive to the exact shape of the radius but there have been very few studies, but such studies of the shape of blend radii do exist. Perhaps a master's degree progam in design engineering would have such a library or try going throught their PHD papers in the old basements. Second - plan on adding a coating to the area no matter how you change the quench or temper (the Q & T you mentioned). This will protect the finish where failure begins. I have studies dynamic failure and found surface polishing in the usual drum polish is very effective.
Dear Friend,
While there are many suggestions, I have one too.
I have seen such failure on turbo shaft of diesel locomotive. One possibility is that this type of failure could be controlled by using hollow shaft rather than solid shaft. The failure is due to tortiona;l vibration than anything else. The material 4340 in Q&T condition is sufficiently good material.
MRCN
od and put a large fillet before hardening
the shaft. Allow some extra stock for
final machining. This might provide better
transition in the hardening pattern as well.
I assume you also used a stress relief after
hardening. I assume your specs call out for
a clean steel and vacuum degassed material
etc. How long is the shaft?
Sorry to be such a late-comer but am compelled to reply, hoping not too late.
You said on Jan 8 "I agree...the other alternative is the increase the diameter of the spline to closely match the diameter of the shaft (Ø6"). This would involve changing another component of the design to match the increase spline diameter."
If you can do this, the gain in torsional resistance, fatigue resistance, reduction of spline root stress, etc will be so dramatic that it pales all the other suggested fixes by a HUGE factor. Compare the Polar section modulus of 4.7 vs 6. It is a cubic function and therefore you DOUBLE the torsional strength. You said the 4.7 will handle the torsional stress but you need to increase the endurance limit.
If this is still an alternative, DO IT because this will save you oooooodles of headaches trying all these different suggestions. Not that there is anything wrong with the suggestons if you have the luxury of "trying them".
We had a similar "design" problem (torsion and bending with splines of 4340) and tried every single suggestion posed here-plus some-except for the astroloy version because instead we finally used maraging steel which doubled the fatigue life. This bought us some time, several years in fact (even though maraging shafts were still fatigueing in as short as 4-6 months in sever applications) to allow us to slowly introduce a new design of a complex gear case including a planetary that had to grow in order to grow the diameter of THE splined shaft that passes thru the sun gear. Our original design did not allow for an earlier unknown reverse torsional load on repeated start-ups. In other words it was a geometry problem such as yours.
For example: Let's say you neck down the shaft at the end of the splines. This could possibly give you a high enough stess at the necked down region to still give you a marginal endurance limit at that section.
And yes you can nitride maraging steel but why use exotic materials as TVP states when more practical solutions are available. A maraging shaft that size would probably cost upwards of $1,500 just for material assuming it is only a few feet long.
Jesus is THE life,
Leonard
One reason for the induction comment is it works similar to drilling the ID but you do not loose moment of inertia. Polishing the diameter and radius before HT is required.
After some searching I have found the Induction information, it is from the March, 1985 Metal Progress magazine. It has a graph that show degrees of twist, torsional yield, and ultimate torsional strength, another graph has fatigue test data. Although this information was test data for SAE 1040 shafts, we used it very successfully on 4340.
The best draw temper for overall axle applications is about 350F. We specified 350° to 375° F so the heat treat shop could actually hit a target. This temper should allow over maximum twist in relation to length and exceed 1,500,000 cycles if not over stressed.
The case has a hardness of approximately 55 RC, and should be about 15% of the diameter in depth if possible and dropping to 30 RC at the core.
We found this to more than double the life of any carbon steel material that was quenched and tempered in a torsion bar subjected to bi directional twisting.
