ELECTRIC MOTOR SELECTION FOR A PCP PUMPS
I would like to get some information about how to select the right electric motor for an oil pcp pump application.
My client has a 50 HP motor and they need to change this, but they think that this motor is to high for their application.
Best regard,
Neca.
Best regard,
Neca.
RE: ELECTRIC MOTOR SELECTION FOR A PCP PUMPS
what do they think is too high?
PCP is a Progressive Cavity Pump
see: http://www.alumni.ca/~hemme3a/production.htm
and http://www.bakerhughes.com/investor/resources/pdf/Produ...
See them often in Canadian Oil Fields ..
Nasty Application for a drive as the shaft has a wind-up characteristic.
jO
PCP(Progressive Cavite Pump) Systems typically consist of a surface drive and a downhole PC pump comprised of a single helical-shaped rotor that turns inside a double helical elastomer-lined stator. The stator is attached to the bottom of a production tubing string and, in most cases, the rotor is attached to a drive string that is suspended and rotated by the surface drive.
Surface drives are available in direct electric motor drives as well as direct gearbox drives that may be coupled to an electric motor or a gas engine.
In the case that I`m revising, the pcp use an electric motor as the surface drive.
In this moment, I don't have the manufacturer's pump data.
I going to look for this information.
I did the question because I don't know what kind of data is necesary to do the best selection of the electric motor (torque, pressure, speed, etc).
I have to specify the power for the electric motor.
Best regard,
Neca
The pump curves and the mechanical drive configuration are the minimum of information that you will need.
Pump data/curves will give you information about the power required and at what speed ...
The mechanical drive data will reveal how the motor is coupled to the pump ... i.e., direct drive or gear ratio (increasing or decreasing)
And from there, you should be able to determine the requirements for the motor.
Kind regards,
jOmega
Therefore, the posting would also be appropriate in the Mechanical Engineering Forum.
