Removing the brackets from a dimension
Hi
Please can someone tell me how to remove the brackets ()
from a dimension in Solidworks.
Yvonne
Yvonne
RE: Removing the brackets from a dimension
Automationbabe has told you how to create new dimensions without brackets. I recommend this too, since I use the reference dimensioning feature to apply real dimensions.
To remove brackets from the existing dimension, right click on the dimension and select properties. Deselect "Display with parentheses".
JHG
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
