Fanuc keyword and 9000 programs
Hello
We have 15 Fanuc Robodrill machines. I have run into a problem with a couple of them. I know that to gain access to the 9000 programs that I have to enter my keyword then change another parameter to =zero. This works on all but two machines. The keywords word supposed the be the actual machine #'s. ie. machine 1165, keyword was 1165. Evidently 2 have either been accidentally changed or the machine numbers changed some time ago. I have called fanuc and they say keyword cannot be cleared unless I reload all parameters and then I would need a parameter set that was saved before the keyword was put in. (sorry such a long story).
Just wanting to know if there is a way to reset this keyword or maybe go into a Parameter or Diagnostic and see it in Hex or Binary format?
thanks,
Bob
btw the controller is Fanuc 16i.
