Wildfire Config Problem
I have recently started to work with Wildfire. I am having a problem getting a hidden config option that I  used in Pro/E 2001 to work in Wildfire. I assemble all components by coords and I found it very helpful when I was working with large assemblies to use the select by menu option when placing components, I think I had to activate the hidden config option "logical_objects" and set it to yes to allow the select by menu. I have tried to do this but when I assemble by coords it only gives me the "select" option.
Could someone advise me if I am correct in thinking this is the config option to use??? If not please advise on how to allow the select by menu option.
Thank you,
drfaust
RE: Wildfire Config Problem
I don't think it is that:
logical_objects
yes, no
to select intent chains or intent surfaces in models created before release 2000i2, you must first update the model by setting this option to yes.
try looking at this page:
http://www.proesite.com/cgi-bin/config.pro_search.cgi?s...
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Yes you are correct that is the option to select the intent chains. I will look over the suggested page of config options.
Thank you,
drfaust...
Hey Ben thanks for the config.pro sight!
JOSE FIGUEROA JR.
