valve ball surface finish
I am trying to update our ball-valve ball specifications.
I need to provides specifications for a 1.0" dia ball made of 316 SS.
We currently called out 100v (valve grade balls) but there does not seem to be a specification for valve grade balls.
We require a 3 Rma surface finish, with a mirror finish.
Procuring 100v grade balls from some suppliers, we find they only have a 5 Rma finish, and it was dull not mirror.
Does anyone have a specification that addresses valve grade balls (which apparently have better surface finishes, but standard geometry tolerances)
As a side note, why would the 5 finish ball, not have a mirror finish? do I need to specify that? I would have thought a finish like that would have been mirror like.
RE: valve ball surface finish
What service are the valves meant for and why do you need mirror finish?
We made parts for internal use with a very low surface finish with always a desire for a finer finish. Our problem was that the finer we got the duller(matt) the part got. Even though we were under a light band in flatness and finish they wouldn't sell until we polished the part.
they require low actuation forces and extremely low leakage rates. Because of this we have been using balls with a 3 finish and they have always come in with a mirror like appearance. We were told they were grade 100V (valve grade)which supposedly meant they met grade 100 dimensionally but better than 48 for surface finish.
