Ground Piece connection
Gurus
Does anyone knows what is a 'ground piece connection' and how to model it in Solidworks
Thanks!!!!!!!!!!!!!!!!!!!!!!!!1
RE: Ground Piece connection
Are you talking about a grounding strap for a piece of electro-mechanial equipment?
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
We delivered some models for probes and the customer wanted ground piece connection to be added to it.
Can u explain more about it/suggest some sites where I can know more.I should model the ground piece connection.
Thanks very much.
Why don't you ask the customer what and to explain it, because he is the one that is requesting it and I'm sure he knows what he's talking about. If he doesn't then he needs to figure it out. Because it's not our job to figure that out.
Once you get that information then bring it back here and maybe we can help you find some more info.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Be naughty - save Santa a trip.
