ASME Sectio VIII, Div2
A vessel design to ASME section VIII Div2 have been in operation for few years. Is there any where in the code that would allow pressure excursion for a short period.
RE: ASME Sectio VIII, Div2
If I were the owner of the equipment I would say 'don't do it'.
Good luck.
This means that abnormal conditions of operation need not be included in the design pressure, but of course provided some conditions are met:
- the abnormal condition must not occur under predictable or repetitive conditions (otherwise it becomes normal): so only an accidental condition may be defined as abnormal
- as always with accidents, an analysis of the accident issues should be conducted before the plant/vessel is again operated: this analysis might lead to the conclusion that no permanent damage was incurred by the vessel (the procedure suggested by GatorOne is a starting point), or that repair is required (and of course also that some operational precautions should be adopted to avoid repetitions).
prex
http://www.xcalcs.com
Online tools for structural design
For Service Levels that have a low probability of occurrence Sct III allows higher stresses. E.g for Service Level B (which used to be called "Upset condition")the primary stress intensity (and hence the pressure) can be 10% higher than for the design condition.
The details of this become pretty hairy and I doubt that you can used it for your case.
