Major Repair to Aircraft Engine components
An age old question. What would be considered a major engine repair?
I have read and understand CFR 14 part 1, but was hoping to get a few of you to give me some specific examples.
Is thermal spray major? Is welding major? Is brazing major? How about non conventional weld, just a few questions.
Would someone be kind enough to start a discussion
Sincerely
Honest John
Sincerely
Honest John
RE: Major Repair to Aircraft Engine components
The above is assuming no special repair authorization to CFR 14 part 145 or SFAR 36, TC's, LTC's etc. It is unlikely that thermal spraying and non conventional welding that is not covered in OEM's manual will be worth the expense for non structual parts. Brazing, in the form of silver solder, is comonly done and it is not a major repair. Welding of weldable, non structable parts would not be major.
