An Apparent MidPoint
i have a lisp/macro for a button that specifies half the distance between 2 points but when i use it inconjunction with other commands it tends to go with osnaps instead of picking the apparent mid point of the 2 points i had specified such as in this example
i have a horizontal line and a vertical that is a misc distace from the mid point of horizontal line now i want to draw a line starting at half the distance from the midpoint of the horizontal line and the endpoint of the vertical line
ok so knowing that here is the macro i have
'cal;(cur+cur)/2;^M
it works some times but others its just acting goofy like selecting 1/4 the distance or selecting the last picked point etc...
'cal;(cur+cur)/2;^M
if everyone helps everybody the world will be a better place
RE: An Apparent MidPoint
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
I understand what your talking about but on thing i may not allways use the same snap setings while doing this so it is imortant for this to stay variant so that i may need an apparent midpoint between the centers of 2 circles or 2 endpoints or 2 midpoints
what should i do?????
