Run macro from cell result
Is there any way to get a VBA procedure (macro) to run automatically based upon the logical result of a spreadsheet formula cell. I need to test a field value and if true then change the properties of several cells , and later reset the same properties if the valeu is something else.
I do not want the user to push buttons, or use the macro menu.
alanH
alanH
RE: Run macro from cell result
You could use the "Change Event" in VBA. See the example below. In this example, cell A2 gets value 1 if cell A1 is "TRUE", otherwise it gets value 2. Procedure is run every time the worksheet is changed, so no buttons are required.
Private Sub Worksheet_Change(ByVal Target As Excel.Range)
addr = Target.Address
If Not (addr = "$A$1") Then Exit Sub
If [A1].Value Then [A2].Value = 1 Else [A2].Value = 2
End Sub 'WorkSheet_Change
