copper tube dilemna
copper tube dilemna
copper tube dilemna
i need to construct/assemble a 3 dimensional copper structure that has multiple triple-ended corners (which means I need triple-ended connectors) that are TILTED to specific angles. Since the specifications indicate that they need to be easily disasembled - i suspect that the trick would be the connectors themselves. what is the best way to do this? Help!
ps.s the connectors have to be strong enough to hold up the structure. conventional commercial triple-ended connectors do not fit the form of the construction.
