Importing v4.22 Drawing format
Hello, I am trying to import a border and format from v4.22 onto a sheet in a v5 drawing. I can bring it in as a .dxf or .dwg but it then becomes exploded in to lines , polylines etc. I would like it to remain draw text so it can easily be edited on the fly. I am very new to v5 and have had no formal training. Maybe ther is a better way to do this other than importing. I can open the .model of the border and format in v5 no ploblem. It just won't let me copy and paste. I believe it's a detail onece I open it in v5. I hope someone can help. Thanks in advance !
RE: Importing v4.22 Drawing format
Several methods can be used.
Try using script to create a format there are several examples provided.
You can also create a document template.
Go ahead and check out the sample scripts because it gives you the capabilty to resize a drawing.
Basicaly you can have one script to do frame and titleblock
for all your drawing formats.
I have the titleblock completly filled out for the designer automaticaly driven from the work order text.
