bonding guy cables
bonding guy cables
bonding guy cables
Please understand that this is a structural engineer asking here:
Is the mere fact that there is a contact between guy cables connectors enough to provide bonding for a steel tower. The bottom of the guy cables is grounded to three 0.75-inch rods that are spaced 20 feet apart in triangular plan view and 20 feet deep. Or jumper across the conncetion points is required?
RE: bonding guy cables
If the guy wires are simply resting on the structure the connection could develop a high resistance with corrosion products at the interface. You could use a type of grease available from lightning equipment suppliers ( e.g. FURZE in UK ) to seal the interface.
Suggestion: The guy cables provide the longer path and the higher resistance to a lightning strike. Therefore, currents in guys will be smaller.
