FIELD WELDS
FIELD WELDS
I have always been told that when designing the length of field welds, I should multiply my answer by 2 for a factor of safety. Is this true and where is it documented. Thanks.
RE: FIELD WELDS
If you have design that is by code all the welding should be called out and the amount of weld is adequate. There is no need to add a safety factor. The additional welding can be detrimental in some cases. If you think a weld is undersized consult with Engineer in Charge with your concerns.
