Insulated Connectors
When using insulated connectors on any size wire, is there a code of what size connector has to be used. For example,when using 12awg stranded wire ,you should consider using 10-12 connector. However when using these connectors(10-12) on a #12 wire. Its really loose and hard to work with in a production mode(Using a crimping machine).The idea is to move to the next size(14-16 connector), because of the better fit and easier to handle. Which now leads me to the next question of,,, is this a electrical code issue.
Also please keep in mind this 100A enclosure has 3 external recepticals.
RE: Insulated Connectors
If you use the connector on any size or combination of wires not on the list, this would be a code violation.
